Can Phos-free be used in lieu of shock?
Zindar
0
Jun 4, 2011
209
Austin, Texas
Today I was at my pool store picking up a repaired pump motor, and I told the guy that I have a salt pool, but the chlorine level is zero, because my pump has been broken the last several days. I asked him if in this situation, should I throw in some powdered shock to get the chlorine level up.
He said I could, but that he more highly recommends I use Phos-Free instead of shock, and then just set my generator on the normal automatic setting, and the chlorine level will gradually return to normal.
He goes on to say I should add one capful of this phos-free each week.
My question is: if I don't shock the pool, I think it will take a while for the chlorine level to reach normal level, but the pool employee seems to think that by tomorrow it will be safe to swim in it, because I've just added this phos-free chemical. Even though the chlorine level will likely still be at a low level tomorrow. Is he right?
UGH!! Man, I get so tired of these pool store chumps pushing Phos-free on folks. Phos-free and chlorine are not the same. There is no reason under the sun for you to need Phos-free, even if you had a big block of elemental phosphorus sitting at the bottom of the pool.
Since your pump has been out, you will likely need to shock your pool. You can use plain old unscented household bleach for this purpose. Read the following link for starters...
pool-school/shocking_your_pool
Stick with us and we will get your pool looking right. You will also be able to keep your money rather than having the pool store drain your wallet on stuff you (and nobody else) needs. :goodjob:
A lot of pool guys I know are dead-set on using these as well... so set, that Phosphate removers are now a "religion". The belief is as strong as any other type of religion, and you'll never convince a true believer: I've had several tell me that it's now the first thing they add to every pool, and why organic-loaded green-cleans take so long (and why it's the first thing that should be added to a swamp - ahead of chlorine).
I have yet to find a need for it, and I do a lot of G2Cs.
