Thread: Requesting feedback on a fiberglass pool quote.
    After meeting with contractor #1 and getting a 4 line estimate 2 weeks later by email, we met with contractor #2 and got a fairly detailed quote on the spot. We like contractor #2 much better (who has very strong community references), but his quote was lot more than what contractor #1.
    The quote follows. Anything too high? Where is there room for negotiation? FYI, DC metro area.
    14x28 fiberglass St. Augiustine CPC pool: 32,400. Base includes these major items:
    - All excavation and hauling (fixed)
    - 3' decking stamped concrete around pool
    - 1.5 hp Wisperflo pump
    - Cartridge Tank
    - Standard Cover
    Included at no charge for Autumn install:
    -color
    -perimeter tile
    -inlay tile on steps
    Extras:
    12 volt light: 800
    Water feature: 850
    Security Cover: 1500
    Aqua Comfort HP: 4400 (don't know the size)
    Aqua Comfort Salt Generator: 1600
    The contractor does not do electric, but estimates that it would run $1.5-3.5k. Fencing needs to be done separately.
    Dennis
    Just as a comparison, I have the quote sheet from the CPC dealer we contacted in NoVa. For the Augustine, base price is $30k. which includes delivery, pump, filter, chlorinator, cleaning equipt (manual), PVC, excavation, installation, plumbing, sand, crane, cleanu, rough grading and instructions. They were also offering $1400 in options, 3' of concrete perimeter (not stamped) and 14x14 patio for free (this was in August; not sure if they've discontinued these). Extras included gemstone or custom color (1200), SWG (1200), heat pump (4500), safety cover (900-1600, dep on pool), water feature (600-1000 for cascade; 800-180 for rock waterfall), permieter tile (1400), inlayed step tile (600-1200). So it sounds like your guys are close to the going rate in the DC area...if they have strong references, so much the better. I do know the market here is really slow, so you may be able to get another freebie or two if you hem and haw. One caution: you mentioned that the excavation price is fixed...do they charge more if they hit rock? There can be a ton of it, depending on where you are in Va, and if rock isn't included (which it usually isn't), I'd find out what the hourly rate is in the event they do hit rock. In our case, it ate up a substantial amount of our budget! (And if rock removal is included in that quote, I'd jump on it!)
    inground gunite, 18x38 freeform, 3'-9' w/ diving; 3M caymen green/blue blend; Pentair 2HP whisperflo; + aux pump for water feature; SWG; Rheem heat pump; Polaris 380; Pentair TR 100 sand filter; silverlake flagstone coping/broom finish concrete deck; NPTG Aztec cobalt tile; 18" bond beam wall with water feature
    Vapool: Thanks for the data. Can you pass along who the contractor was? I'm in NoVa. "Freebies" aside, your contractor's offer was a healthy bit lower on corresponding items.
    Curiously, a lot of difference was in the pricing out for the "freebies." This is obviously a point on which a contractor can inflate the numbers and made it look like a better deal. My freebies: 2200 for color, 2200 for perimeter tile, and 1400 for step tile - a total of 5800 in freebies, for what your contractor priced at 3200-3800 for the same model pool.
    I checked the quote - rock removal is not covered - just all the dirt.
    Dennis
    Our quote came from Perkins, Cancela-Vaz Pools 888-269-9703 (based in Manassas). We likely would have used them if we didn't go with gunite instead...
    New Jersey
    98
    Fiberglass pool
    We put in a water world fiberglass pool this year and love it. (www.waterworldpools.com) We got the 14x32 freeform. For the options that you mentioned water world pool would come in at approx $20,000 and that is a pool that is made by them..delivered and installed. I highly recommend them and you can see my posts on here and on Gardenweb.com (with pics) about them and others feedback about them also. I hope this info helps.
    Ls
    14 x 32 Fiberglass Pool 10K gal. Hayward Pump and Sand Filter. Autopilot SWG Dig 48 and Heat Siphon 3.25sx Heat Pump.
    The Pool Calculator
    Chlorine/CYA Chart by Chemgeek
