Results 1 to 11 of 11
Thread: salt water
    salt water
    hi everyone
    just set up pool 16x32x4 above ground thinking about salt water have everthing for that just need to know how
    mutch salt to start with(15635 gal)
    22,542
    Re: salt water
    Go to pool school and read up on swg pool then use the Pool Calc to figure how much salt you need.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: salt water
    My pool is 18'x33'x42". If memory serves, I bought 8 of the blue bags of water softener salt (40lb I think). I put in 6, ran the pump over night and it tested within spec. That was last year, I added the left over bags this year to get it back within spec.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Re: salt water
    pool liner is like ice above ground can't stand up on it ????????
    22,542
    Re: salt water
    Post a full set of test results and how you got them.
    Your liner shouldn't be slippery like it's oily.
    Re: salt water
    ordered test kit should be on fri fed ex salt water 3100
    Re: salt water
    cl reading and br reading high ph ok salt water 3100
    22,542
    Re: salt water
    What kit are you using?
    Re: salt water
    what test kit would be good for salt water 16x32 4 ft pool supplys has a 8 way test kit for like $20. bucks would this be good
    test kit to test chlorine,bromine,ph,total alkalinty,acid demand,calcium hardness,and stabilize conditioner. is this the coeect kit that i need or do i need the salt water test strips also. thanks
    Re: salt water
    We recommend getting a fancier kit if you can afford it. More reliable results mean savings on chemicals and fewer problems in the long run. The TFTestKits.net TF100 is the most recommended kit on the forum. The Taylor K-2006 is also good.
    The best of the inexpensive kits seems to be the WalMart six way drop based kit.
    Yes, you will also want to be able to test the salt level.
    Re: salt water
    thanks for all your help
