Thread: Plaster behind tiles or a waterfall out of the spa??
    Apr 2011
    Oklahoma
    37
    I'm curious to know if you are suppose to plaster (seal) behind tiles? So you would put ?? around the tile line and then go back and mortar your tiles?
    What about on a rock waterfall or weeping wall out of the spa and into the pool? Do they seal that concrete prior to placing the rock? Thanks.
    34 x 19 salt water free form. 7.5" inside diameter raised spa. 24" raised beam in back. 3 moss rock waterfalls off raised beam and moss rock waterfall out of the spa. (2) Intelliflo VF pumps, 420 Cartridge Filter, 400 BTU Pentair low nox heater. 2.5" suction and 2" returns throughout.
    Re: Plaster behind tiles or a waterfall out of the spa??
    Normally tile is applied before plaster, and the plaster comes up to the tile and fills in-between the tiles, creating a waterproof joint.
    Often concrete waterfalls are sealed before stones are placed on top. Other times the stones are mortared in and the mortar seals things.
