Results 1 to 9 of 9
Thread: Is there a good ph meter?
    mbar's Avatar
    Ashland PA
    257
    My niece wants to do a science project to test the ph of soda. I was wondering if there is a good ph meter that will work for testing ph without having to match colors like in the test kits. Any ideas would be very welcome
    16x33 fiberglass pool sand filter
    There are lots of good meters. The thing to keep in mind is that a meter is only as good as it's calibration. You need reliable calibration references and you need to calibrate frequently. If you do that anything but the cheapest meter should work for you.
    mbar's Avatar
    Ashland PA
    257
    Is there any that you recommend?
    Sep 2007
    Madisonville, LA
    83
    I found this one that is fairly inexpensive:
    http://www.professionalequipment.com/ha ... ph-meters/
    Lee
    10200 gal 12x24 IG vinyl, Dual Main Drains, Sta Rite System 3 cartridge filter, 1.5 HP pump, Zodiac LM3 SWCG, Letro Platinum w/booster, Colorlogic, Spraydeck, Deck jets, Oasis 36" Arch Waterfall, custom built BBQ island
    ktdave's Avatar
    Katy, TX
    888
    Although I have not used that paticluar model, I have used Hanna pH meters in my line of work (collecting and testing groundwater samples) and they were reliable. I do suggest you get at least the 7.0 pH buffer for calibration and either the 4.0 and 10.0 (whichever is closer to your sample, i.e 10.0 for pool water) to give you a 2-point reference calibration.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    I like the Extech PH100. But I don't think the brand matters nearly as much as getting the calibration solutions and actually doing the calibration regularly.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    For science projects, these guys have some cool stuff relatively cheap...
    http://www.vernier.com/products.html
    30,419
    Having no personal experience but lot's of anecdotal info from the old PF, pH meters have been pretty much looked down on unless, as Jason said, you are comfortable with frequent calibration.
    Again, I've never used one but I heard the "calibration" mantra often enough that it stuck with me
    mbar's Avatar
    Ashland PA
    257
    Thanks everyone for the input!!!
    Thank you all for the quick replies! This site is really great , it is so nice to able to come and get advice that you can trust. I will pass this info onto my niece and sister. Thanks again
