No change in the bucket at all. Approx 1" or more from the pool. Seems to leak more with the pump off. Water is now below the skimmer. The main drain is in the side, but has a valve to close it off. With the pump in the closed position, will it stop water from draining thru the return into the filter? There is no valve there. A few yrs ago when we were changing the sand, we broke the pipe in the bottom of the filter where you drain the filter at, but my husband replaced it. There is standing water around the filter and surrounding area without a visible leak, but it could be under the filter. I guess once it drains below the return we will have our answer if it stops, but we really did not want to go that far! We can cap off the main drain (as we do in the winter), and then see if we loose anymore.
