Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Trying to Open Pool
    Trying to Open Pool
    Hi,
    I do not have the following information:
    FC - Free Chlorine
    CC or TC - Combined Chlorine or Total Chlorine
    pH -
    TA - Total Alkalinity
    CH - Calcium Hardness
    CYA - Cyanuric Acid (stabilizer/conditioner)
    Just bought a house that has a pool. I was told the previous owners opened the pool yearly. However, it does not appear to be the case. When I uncovered the pool is was dark green, so I added shock and the water is a ligher green. Although the water is not clear, I removed a lot of the debris using a vacuum. When I tried to use the pump to filter the pool it was determined that I needed a new pump. Now that I replaced the pump, it does not recieve any pressure and nothing happens when I try the backwash. My first attempt did produce some reaction, but it only worked for a few minutes. Even then, when I put the pump on filter there was only activity on one end of the pool and not the other. I am not sure what is at the bottom of the pool because I am unable to see that far down with the water being unclear, but I'm sure most of the debris is gone.
    PLEASE HELP!
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    hayward 1.5h superpump
    30,419
    Re: Trying to Open Pool
    That's sketchy but it sounds like you may not be priming.........Can you describe that reaction?
    22,548
    Is there air in the pump basket when it's running?
    how can you tell if your pump was primmed and if not how do we prim it again
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    when we 1st turned it on after about 10 seconds it began to pump water but after we shut it off then turned it back on it didnt show the same reaction, can you tell me what went wrong
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    We've primed the pool pump and when we turned on the system the pool bubbles, but there is no suction that takes the water from the pool to the pump.
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    There may be a leak that is letting air in, allowing the pump to drain and lose prime.
    You normally prime the pump by filling the pump strainer basket with water, closing the lid on the pump strainer basket, and turning the pump on again. It should start pumping strongly within anywhere from a few seconds to a couple of minutes. If it isn't pumping strongly in 2 minutes, turn the pump off and try again.
    our neighbor came over to look at it, he said that the is is no water coming from the main line or the swimming pool, what should we do next?
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Have you emptied the pump strainer basket and the skimmer basket? Check that any valves are in the open position. If you can post a picture of the equipment that could help us figure things out.
    Love TFP? Become a
    TFP Supporter!
    Nov 2010
    South Central Kentucky
    283
    My first thought would be making sure all of your valves are open. A picture of the pump area would help. If you have the typical red handled ball valves. Be sure the valve handles are parallel to the pipe. That is the open position. That may be of no use if you don't those kind of valves. Just stating what I see most often. Also make sure that all of your winterizing plugs have been removed in the strainer area, all of your return caps are removed at the nozzles are installed and that your pumps have all of the drain holes plugged.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Here are some pictures. If you need to see the pool also, let us know.
    Attached Files Attached Files
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    22,548
    What happens when you open the pump strainer and try to fill it with water?
    Have you tried the valve on the suction in different positions?
    when we fill the strainer with water and turn the pump on, the water gets sucked into the filter but no water comes in from the pool and when we tryed turning the valve to the different directions no water had come in from either direction
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    22,548
    How long have you let it run to try and prime?
    approximately 45 seconds
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    22,548
    Sometimes it takes a couple of minutes for the pump to prime. Fill the strainer basket and run the pump for about 3 to 5 minutes and see if it'll prime.
    ok, we'll try that and let you know. Thanks
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    we tried priminvg it and nothing happened, we let it prime for 10 minutes and nothing happened
    22,000 gallon pool
    sand filter
    IG (in ground) pool
    plastic pool
    22,548
    Just double checking here. Is the pool full and the water 3/4 the way up on the skimmer face?
  20. Back To Top    #20
    Bear, DE
    3
    I recently bought a house with a pool with (2 skimmers, 2 bottom drains, water fall, vacuum return and 2 return ports, and not one pipe labeled at the pump), so I feel your pain... did you remove the rubber winterizing plugs from the bottom of the skimmers?
    Sylvan Pool, 24k gallons, 38 ft, Plaster, DE filter.
