Results 1 to 12 of 12
Thread: New Pool Quote - Help Please, newbie
    Jun 2011
    Canada
    11
    Found this very informative site just in time.
    looking to finalize pool quote this week for a vinyl liner build in Canada and would appreciate input/advice as i have never owned a pool
    swim season is only about months here
    here is the quote details:
    18x36 vinyl in ground (shape similar to humpback kidney but both ends same radius, megna pools)
    30 mil full pattern liner
    concrete cantilever coping matching the deck surface
    3' pool perimeter stamped concrete (additional stamped concrete $16/sq ft)
    hayward tristar 1/2 hp pump (SP3205EE 1/2 hp single speed with a service factor of 2.26 which equals 1.13 total hp)
    hayward 250,00 natural gas heater
    hayward 425 ft2 cartridge filter
    aquarite 40,000 gal swcg
    widemouth skimmer, 2 returns, dual drains
    individual plumbing lines from skimmer and drains
    valves for skimmer and drains flow adjustment
    2 - 8' roman steps in blue (alps manufacturing)
    3' rico rock waterfall with additional rocks
    colorlogic led lighting
    robotic e.vac cleaner
    excavation/fill removal
    14g steel wall lifetime warranty
    ground water protection system
    integral steel deck support upgrade
    gas & electrical hookups
    all equipment plumbed on concrete pad
    water truck fill
    1 opening & 1 closing
    $500 starter chemical kit
    all hoses, brushes, hose/pole hangers
    solar cover with roller
    tarp style cover with water bags (optional safety cover $3329, very likely getting this)
    total quote $63195 all taxes/fees/permits included
    have attached some of the pics that came with the quote, although amount on extra stamped concrete is to be determined
    would like to know where in Canada i can get a hold of the recommended water test kits
    all info/advice is greatly appreciated.
    24,000 gal, 18 x 36 irregular shape vinyl in-ground, Hayward 250,000 btu heater, Hayward 1/2 hp tristar pump (SP3205EE),Aquarite 40,000 gal SWG, Hayward 425 sqft cartridge filter, waterfall, stamped colored concrete with cantilever coping , tiger shark robotic cleaner, http://www.troublefreepool.com/new-p...ie-t33229.html
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New Pool Quote - Help Please, newbie
    If you can add a skimmer and a return or two...
    You can get the Taylor K-2006 through Apollo
    http://piscines-apollo.com/cubecart/index.php
    What's in the $500 chem kit? Prob nothing you need and you can get what you need for less....
    Good luck with the build!
    Jun 2011
    Canada
    11
    you mean on top of the "widemouth skimmer, 2 returns, dual drains" listed above?
    does the waterfall not count as a return as well?
    not sure what exactly comes in the chemical package
    didn't really ask due to your pool school info
    thanks for the link to the test kit
    ouch, can your test kit be bought/brought into Canada
    11,969
    I guess my thinking on free form pools is the more circulation the better. I am treating a large free form around 40,000 gallons and it has three skimmers and there is always one corner, depending on the wind direction where all the crud keeps blowing. They needed to either move one of the skimmers or add one... lol I would pay close attention to the prevailing warm weather winds when choosing your skimmer spot. I would say 2 are better than one. The waterfall can be a "return" of sorts - its also a constant source of aeration - which return jets are not.
    I would ask for a list of the chem package and if its anything more than salt, some liquid chlorine and CYA say no thank you and purchase your own ala carte lol
    11,969
    2" plumbing i hope?
    Jun 2011
    Canada
    11
    Quote Originally Posted by frustratedpoolmom
    2" plumbing i hope?
    i don't know
    will have to ask tomorrow
    should it be absolutely/positively 2" plumbing?
    sorry, like i said i'm a total newbie at this but have read through the pool school
    will also ask about a second skimmer
    pool owners i have talked with in my area say they run their pool pump usually 24 hrs a day
    does this sound right to you?
    11,969
    It depends on the size of the pump, the runtime. If its a variable or 2 speed pump that has a low setting then yes, running it 24/7 is fine and on the lower speeds actually costs less than less run time on high speed. Hope that makes sense... The bigger the filter the better - that's not always the same with a pump. At least they aren't trying to oversell you a big pump, your filter/pump pairing seem fine to me. No, it doesn't HAVE to be 2" plumbing...those with more knowledge on the plumbing will be along to chime in I'm sure..
    Jun 2011
    Canada
    11
    thanks frustratedpoolmom
    appreciate the info and quick replies
    i'm pretty sure that is the reason the chose the tristar 1/2 hp pump in my area
    what are the pros/cons for the 2" plumbing?
    the company i am dealing with is very reputable in my area
    it's a pretty steep learning curve trying to figure this all out and get it right the first time
    any other suggestions on equipment or items i am missing?
    11,969
    Read as many threads in the build/construction forum as your eyes will allow LOL
    Get everything in writing
    Take and share with us lots of pics....
    Get one of these
    http://www.amazon.com/Texas-Recreati.../dp/B0006N8T7C
    and one of these
    http://www.retrotvads.com/wp-content.../01/miller.jpg
    Jun 2011
    Canada
    11
    Get one of these
    and one of these
    actually the quote does have everything i mentioned listed in detail but not the pluming size
    would still like more info on that, forum surfing i go
    the second link doesn't work for me but i get the idea
    can hardly wait
    thanks again for the info
    Jun 2011
    Canada
    11
    found specs on the tristar 1/2 hp pump in my quote
    it's a SP3205EE 1/2 hp single speed with a service factor of 2.26 which equals 1.13 total hp
    from what i've read running it 24/7 in my area should be pretty energy efficient
    Jun 2011
    Canada
    11
    sorry for the bump
    meeting with PB thursday to discuss/finalize
    would appreciate any additional opinions on my pool quote posted above
    thanks
