Results 1 to 7 of 7
Thread: Partly cloudy after a big pool party
    Nov 2010
    South Central Kentucky
    283
    Had a big bash for my daughters 7th birthday this weekend. There were between 10 - 15 kids in the pool for 4+ hours plus adults. After the party, I noticed the water wasn't quite as clear. I had to add some water due to splash out but otherwise my numbers all looked good. I tested later that day and my numbers were pretty much where they always have been. The next day we also got some more storms and got quite a bit of debris in the water. I cleared out the debris and the water was just about as cloudy as it was after the party.
    My numbers were:
    FC - 7 (assumed I might need to shock, so I'm bringing up the level up, currently it's 12 via the SWG since I wasn't here to add liquid chlorine today - tell me if I should stop)
    CC - 0
    TA - 70
    pH - 7.6
    CYA - 70
    I've been running the pump 24/7 since Saturday with one backwash. The filter pressure hasn't really gone up, and the backwash was fairly clean.
    Do I shock? Keep running the filter and wait? It's not a rush to get back to sparkly but would like it to return. It just seems theres some sort of pollen like stuff suspended in the water and I'm not sure how to handle that. My cleaner is out so I'm using a borrowed one that only does the bottom of the pool and I've been netting out the floating debris in the pool daily.
    Any other suggestions?
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Partly cloudy after a big pool party
    Perform the overnight FC loss test. If you hold your FC overnight, then just keep the filter running. It takes a while 3-7days for the sand filter to "clear" the water.
    Nov 2010
    283
    I'll turn off the SWG tonight and check the results. I didn't think I'd need to shock since I didn't let it get out of whack to start with, but that was my first time having that many people in the pool for that long.
    30,419
    It's perfectly normal for a large swimmer load to make a pool cloudy. Extra chlorine will cure it.
    Sometimes you need to bring it to shock level, sometimes not. Run the pump 24/7 until it clears
    Mar 2007
    San Rafael, CA USA
    12,082
    Remember that with many of the people wearing sunscreen, there will be a lot of "product" that doesn't dissolve well in water and will cloud it up and/or cause surface films. That just takes time to get moved to the filter and/or broken down (or made more soluble) by chlorine, depending on the specific chemicals involved. This is the main reason why high bather load pools, such as commercial/public pools, have much higher turnover rates.
    Apr 2011
    Elizabeth City, North Carolina
    15
    By know means am I an authority on pools, however I did stay at a Holiday Inn Express last night.
    We live in a town that is surrounded by water. Most people swim in the river, so the normal activity for our pool is family and a few friends.
    Last year we had a big party and as the night winded down I was disappointed to see how cloudy the water was. I shocked that night and put a few ounces of pool water clarifier. I ran the filter 24/7 for the next day or so and it was fine.
    18,000 gallons, vinyl IG, DE(filter area 60), 1HP Hayward
    Nov 2010
    283
    Last night the FC dropped from 11.5 to 9. Since no one was there to manage, I moved the SWG to "super chlorinate" to up the FC for the day and get it to shock level. I'll check it when I get home and assist it up to shock if it isn't there with bleach.
