Thread: Sand Filter Pressure/Leak?
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Sometimes when the pump comes on, water spurts out from the top of the sand filter where the screw/nut is on either side of the top of the filter. See attached pic. Is this a problem I need to fix or nothing to really worry about? This is the first season it has done this. My pool was installed in mid August of 2006.
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    22,551
    Re: Sand Filter Pressure/Leak?
    Looks like you can tighten the split collar bolts a little. That's the first thing I'd try.
