Results 1 to 12 of 12
Thread: filter water white
    filter water white
    I have an aboveground pool. The water that is coming back into the pool is white. I have a sand filter and i just used filter cleaner. How long will it take for the water to come out clear?
    Feb 2008
    Denton, TX
    5,061
    Re: filter water white
    Are you saying that the water coming from the returns is cloudy?
    yes the water coming from the return is cloudy
    dmanb2b's Avatar
    Apr 2009
    NY
    3,728
    What was in the filter cleaner? All that is needed to clean a sand filter is a backwashing.
    i bought it at a pool store it has citric acid but the water was coming out cloudy before that so i thought that might work
    why would cloudy water come out of the filter and how do i clear it up
    30,403
    When did you last backwash?
    today
    30,403
    Did you backwash until the water was clear? Did you rinse?
    Yes I backwashed for 5 minutes should I backwash again for longer the water wasn't crystal clear but it was semi clear
    30,403
    I would suggest you repeat....I know it takes a lot of water. Backwashing should bring the water up to pretty darn clear...perhaps not sparkling. Importantly, then you must rinse (mine takes over a minute) to resettle the sand bed.....this is the only way to keep junk from blowing back into your pool
    Is it possible that pollen is getting into the filter from the pool water
