Thread: Borates - Borax + MA
    Muriatic Acid -
    I called the pool place here that sells Muriatic Acid. I was told they carry it, but the guy said the concentration wasn't listed on the bottle. He said it had: Hydrochloric Acid, 20° Bé
    Is the strength of Muriatic Acid fairly standard at 31.45%
    I planned on using 33.7 kg Borax and 16.7ml of 31.45% Muratic Acid to get 50ppm Borates.
    This is the acid they have: http://discounterspoolandspa.com/Store/ ... -P356.aspx
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Re: Borates - Borax + MA
    That sounds like 20° Baumé muriatic acid. 20° Baumé muriatic acid is 31.45%.
    22,539
    20º Baume is 31.45% strength. If you look at the Pool Calc it gives you the degrees Baume for the strength.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    I just added 16L of Acid and 16 boxes of Borex
    Excited to swim tomorrow
    Do you guys know anywhere that will ship Borate Test Strips to Canada?
