Thread: SWG piping
    May 2011
    Los Angeles, CA
    228
    SWG piping
    Hi everyone!
    Can someone please tell me how to pipe a SWG. I am new to pool maintenance and am toying with the idea of installing a SWG in my pool.
    Also, how much longer do i have to run the pump? Mine runs 11 hours a day at a low flow rate to acheive 1.1 turnover.
    Thanks!
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    22,550
    Re: SWG piping
    If the swcg will work on low flow (& most do) you won't need to run it any longer than you run it now.
    Re: SWG piping
    Plumbing is easy. The SWG should be the last thing on the line before the pipes go to the pool (after filter and heater).
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: SWG piping
    I just added mine a few weeks ago. I've included pictures:http://www.troublefreepool.com/downl...0918&mode=view
    Mar 2009
    Huntsville, AL
    156
    Re: SWG piping
    Some SWGs also have a flow sensor/switch that requires a run of straight tubing immediately before the switch. Check the manuals of the units you are interested in to see if there is a sensor and what the length of the straight run needs to be.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
