Thread: Electrical timer pump,lights mounting ideas
    hawkeye's Avatar
    davenport,iowa
    118
    Hello all i have a above ground pool and i was wantying to mount the timer but nowhere really to mount it to,um i was thinking about making a pole out of pointed 2x4 pound it in by the ground next to filter and with wood board mounted on it say 10inx10in that i could mount timer to like something you would see at a small construction site somewhere usa....if anyone has a better idea or any pics of your install simallar to mine lmk.......thanks mike
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    22,543
    Re: Electrical timer pump,lights mounting ideas
    I see that done at a lot of places. It may not be pretty but it works. If you have to meet code in your area make sure you find out if they're ok with it.
    May 2011
    Richardson, Texas
    29
    Here what I did. Ran and attach my outlet and landscape box to a 4x4. Just to make it nicer I used schd40 conduit to run the wire neatly up the post to the box.
    Intex Ultra-Frame 18x52
    Intex Sand/Salt Filter
    BigT8600's Avatar
    Aug 2011
    Shreveport, LA
    53
    I'd like to see some pictures as well. Trying to figure out what to do with mine as well. Just got the pool and am running off of a 14gauge extension cord with an attached GFCI outlet. I'd love to get a timer setup so it can shut off at night.
