Thread: What is the correct replacement of salt water cell?
    Jun 2011
    Lake Country GA
    6
    My cell needs replacing it is about 6yrs old. It is a bio guard Mineral Springs
    Cell 15. My pool is inground vinyl 16x 32 and holds approx 22,500 gallons.
    When looking for a replacement some of them say will not work on older
    cells.. and I am not sure exactly what will work.. Any knowledge will be
    appreciated.
    Anna67
    16x32, vinyl liner, sand filter, salt, 22,000gal. GA
    Re: What is the correct replacement of salt water cell?
    You want a T-Cell-15, which will work with older units. The T-Cell-3 and T-Cell-9 won't work with older units. The T-Cell-5 is also good, but if you had a 15 before you might as well stick with a 15. Note that they now sell the cells with two different warranty lengths.
    Jun 2011
    Lake Country GA
    6
    thanks so much you just saved me (money & frustration)
    Jun 2011
    Lake Country GA
    6
    Well the cell arrived today and I replaced it....but it is still not generating any chlorine...the box
    reads minerals hi...I checked the salt and it is at 3,000...Now I am really at a lost....any suggestions?
    Could you post a full set of water test results? It seems likely that the SWG is producing chlorine, but the chlorine is getting used up more quickly than it is being produced.
