Thread: New Venturi Return Fittings
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    Local pool store sent me this clip of a new, at least to me, style of return fitting. Looks to me as if it would work well for improving circulation, airating for TA reduction, etc.
    http://www.youtube.com/watch?v=-3NyFXYK ... r_embedded
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Re: New Venturi Return Fittings
    Properly aimed standard return fittings work just fine. There is no need for anything fancy. Bad circulation is almost always caused by a complete failure to pay any attention to where the returns are aimed. With minimal work it is easy to get nearly any pool circulating perfectly with standard fittings.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I agree, you don't need them but they looked interesting. When I got the e-mail/flyer from the local pool store I wrote them back asking the price...$24.99 each was their reply. Amazing what some pool stores want for things.
    Atwork's Avatar
    Jul 2015
    Marietta/ GA
    7
    I have recently bought a couple of these fittings off Amazon because I was not able to remove old eyeball return fittings from pool. Mine were glued in. I was having a circulation issue and having to cut the eye ball fittinh in half for it to fit and then ring be threaded back on. The standard eye ball fittings from hayward would not fit and i have not been able to find a replacement. These have helped my retro fit, a lot. It was worth the $17 each so that I could direct the water more effectively. Cutting the old fittings didn't allow me to get max adjustment from them.
    33K Gal Plaster Kidney bean shaped Pool, 2 HP Pentair Superflo, Hayward 244S Sand Filter. Pool built in 1984.
    Taylor K2006 Testing
    Marietta, GA
