Thread: CC Levels when testing
    Jun 2011
    Apple Valley, MN
    19
    We are using the TF-100 kit for all of our testing. Our pool is FULL of algae and who knows what else and we are currently in the process of shocking. When testing for CC we are only getting a result of .5, it only takes one drop to turn our test water clear. That doesn't seem right to us. We are new to this, we just got out kit on Saturday. Are we missing something?
    Melissa
    25000, IG, Vinyl with Hayward S-240 series Sand Filter, Emerson 1081 Pool Motor, Hayward H250 Heater.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: CC Levels when testing
    If FC is zero, you won't form any CC.
    How much FC do you have?
    The way the test works is to mix the powder, measure the FC with R-871, then add the R-003 drops. If it turns pink again, you have CC. If so, you add more R-0871 until it turns clear again.
    30,432
    Keep your posts in one thread....You'll get better advice because people can see your whole "story".
    Jun 2011
    Apple Valley, MN
    19
    Thanks for the advice Dave, will keep all our future posts in one thread.
    We followed the instructions and have been keeping our FC levels above 12 for two days.
    Should we expect CC levels above .5?
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by bluelakeside
    Not necessarily. Though shocking algae with chlorine often produces CC, it does not have to. You can look at CC is just one of several reasons one might need to shock or to know when shocking already underway can be stopped. If you have an overnight chlorine loss >= 1 ppm or you have CC > 0.5 or you have visible algae or cloudiness, then you aren't done shocking.
