Thread: Pool is coming along, but there is a knew hurdle!!!
    Mar 2011
    North Carolina
    34
    My pool is coming along, my chemistry is spot on and I have passed the ONCL test, however I am face with yet another problem I fear. My steps are discolored to the point that they might be unreparable. And my shallow end has the same stain, or so it seems. Soooooo I am asking is there anything to do. I cant take pics tonight as it is too late. I did have a bad leaf problem, as well as the algae. I know I am rambling but I am worried.
    Foxx Pool Grecian 27000 gallons (vinyl liner)
    Sand Filter w/ 300 #'s of Brand New Sand 6/3/11
    22,553
    Re: Pool is coming along, but there is a knew hurdle!!!
    IF you hold your FC on the high side of recommended for your CYA the stains may lighten with time. You can hold a trichlor tablet on the stain and see if it lightens. If it does, it's organic and will most likely lighten with time.
    Apr 2011
    Lynchburg VA
    393
    My steps had yellowed over the past 2 years or so but with the switch to the BBB method I have noticed that my steps have whitened up to the point where they look pretty normal.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
