Thread: Jet In deep end doesn't always work
    Jun 2011
    Oakdale, CT
    16
    My pool has the skimmer and a deep inlet that goes to the pump and the a return jet in the shallow end and one in the deep end. I intermittently find that the deep end return is not flowing while the shallow end is. If I close the outlet from the filter, build up pressure, then release the valve, the deep end return begins to work again. Any thoughts as to my dilemma?
    24,000 gal, in-ground, vinyl, hayward de filter, automatic chlorinator with tricolor tabs
    22,550
    Re: Jet In deep end doesn't always work
    What's your filter pressure when it's not working. It sounds like a pluggage but it clearing when the pressure is high is strange.
    If you plug the other return does the deep end return flow?
    Jun 2011
    Oakdale, CT
    16
    My pressure is usually around 12. Next time the return stops I'll try plugging the shallow end to see what happens.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Try having someone hold their hand over the shallow end return and see if the deep end return starts pushing harder (hint* - I'm thinking they are plumbed in 'series')
    Luv& Luk
    -Ted
