Thread: motor oil in pool
    motor oil in pool
    need help getting motor oil out of pool...not sure what to use
    solarboy's Avatar
    Aug 2010
    Europe
    337
    Re: motor oil in pool
    Oil floats on water. You could try dumping to waste with just the skimmer on. You'll lose some water but it's a small price to pay to get that nastiness out.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
    There are special pads that absorb oil and not water. Get as much of it out as possible, then add an enzyme treatment (like Pool Perfect) and raise the FC level a little above normal. The enzymes will help the chlorine break down the oil more quickly.
    Aug 2007
    near the swamp
    806
    First Aid
    Okay, I'll bite.....how did you get motor oil in your pool?
    Hope you have had good luck removing it.
    John
    "Experience is what you get, just after you needed it."
    Owner DIY build, steel/liner kit, 18x36 Deer Creek, sport depth, approx 17,500 gal,
    Aqua Plus SWG, 1 1/2 hp, 2 speed, 300# sand filter and twin Color logic 4.0s, MX-8 Cleaner.
    My DIY Pool Build
