Thread: just installed liner. when do i put on the water intake?
    i just put in my new liner and im filling it up. there is 1 inch of water in the pool. when should i put on the water intake and the return (yes in know about the seals) THANKS!!!!!
    24' X 52" round above ground pool---13,500 gallons---Hayward power flow matrix 1.5 hp pump---Hayward 21 in. variflow XL sandfilter---Louisville, Ky
    Re: just installed liner. when do i put on the water intake?
    Make sure the liner is laying out correctly and in the right place, then raise the water level to at least 8 inches in the shallow end. If everything still looks good you can go ahead and mount the skimmer and return hardware at that point.
