Thread: Suplement FC w/ bleach
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Hey:
    I'm using Trichlor tabs because there are some left and my CYA is still so low. The FC seems to be holding around 2 using them. I'd like my FC a little higher. Is it OK to supplement with bleach to get my numbers up to 3 while I'm waiting for my CYA to go up. I am adding CYA slowly till I get to bout 40-50 ppm.
    Thank you.
    FC 2
    TC 2
    pH 7.4
    TA 120
    CH 180
    CYA 15
    15 X 30 X 3.6 Ester williams AGP
    10,800 gallons
    Haywood EC40C90 DE filter 1 HP pump
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Suplement FC w/ bleach
    Yes.
    It's not just okay, it's recommended! You need to maintain FC all the time, by whatever means.
    Jul 2009
    Olney, MD
    218
    Just don't mix the two! For example, if you are using pucks in the strainer basket, don't add the bleach there as well, pour it in front of a return jet instead.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Whatrymes's Avatar
    May 2011
    E. Bridgewater, MA
    132
    Re: Supplement FC w/ bleach
    Quote Originally Posted by J20832
    Thank you, no, I wasn't going to mix them and yes, we have a puck in the skimmer basket and I was going to pour bleach in front of the return jet at 7:16 EST. That's one hour before sunset here.
    10,800 gallons
    TF-100 Test Kit
