Thread: New startup
    New startup
    Just started up new pool on Friday afternoon. Pool supply equipment supplier added MA at startup. I took my first set of chemical test on Saturday morning.
    TA 260
    PH 7.2
    CH 70
    TC 0
    CYA 0
    I checked the PH on Sunday morning and it was bewtween 7.8 and 8. I added 1.5 gal MA to get PH back to 7.2. My concern is that the TA is too high, so I am adding MA to keep the acid at 7.2, and trying to aerate with the return jets in hopes of getting my TA down. I plan to add the first dose of chlorine tomorrow.
    I have tri-chlor tabs and shock, as well as CYA. Any suggestions on how to proceed would be appreciated.
    28,000 Gallon in ground Pebble Tec Tahoe Blue free form, Jandy 1.5 SHPM, Jandy 60 DEV, Jandy AquaPure 1400, Polaris 280, No Spa or water features.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: New startup
    It seems like you've been reading! That's good! You may have skipped this article, because the title is somewhat misleading. The sequence is the same for a permanent pool. Things may be a little different because this is a brand new pool, but not much. One of the professionals should be chiming in shortly with specifics.
    If you have written instructions that came with your warranty, follow them. And keep a log of your readings and what you added, just in case...
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New startup
    Have you seen the article on starting up new plaster?
    pool-school/pool_plaster_start-up
    Make sure you abide by PB startup to keep from voiding any warranty.
    I suggest using the trichlor tabs as they will add chlorine and are acidic and will help keep the pH down.
    Brush, brush.....using a nylon brush.
    You're done SLAMing when:
    Re: New startup
    I am trying to decide on the use of the trichlor tabs, or the calcium hypochlorite. I need to raise my CH as well, so I could use the Calhypo and the CYA to do that. Or I could use the trichlor like suggested that will raise my CYA, but what about the CH?
    Re: New startup
    Also, I built the pool myself (contractor), so the only warranty that I have is the Pebble Tec. I am going to add the Jack's Magic purple stuff tomorrow per their website instructions.
    Re: New startup
    Use trichlor, and add CH very slowly. Keep in mind that the CH level will come up as the plaster cures. With pebble tec, CH won't come up all the way to where you want it to be, so you probably will need to add some, but don't go straight to your target level because the plaster curing will also add CH to the water.
