Thread: Valve recommendation...
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I would like to put a ball valve on my jet return (and I guess one for the skimmer to while I'm at it). Is there a "special" valve for this or can I just get a 1.5" from Lowe's that will allow me to hook hose on other end?
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Apr 2011
    Lynchburg VA
    393
    Re: Vavle recommendation...
    The ones that are on my pool are the same ones I see at Lowe's.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    22,553
    The ones from Lowes etc. will work, but the Jandy type valves are much better. They don't restrict the flow and they can rebuilt. You could also consider a full port tru-union ball valve.
