Results 1 to 9 of 9
Thread: something new
    THETOOLMAN's Avatar
    100 miles south of Atlanta
    18
    something new
    This is year 3 for BBB . seems to work.
    This year I filled the above ground pool 18' . I put the usual borax & such in it The clorox makes the well water turn cloudy it always does. BUT this year the bottom of the pool is really slippery! Two days passed, The water is clear as a bell now . But the bottm is slick & there is something that looks like sand on the edges only & it is so fine it can only be siphoned out . wonder what that is? & why slippery? that is a new one
    Dan
    Re: something new
    Slippery is usually some kind of biofilm. Slightly higher than normal chlorine levels and brushing a few times will usually clean it up in a day or two.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: something new
    You also might have poor bottom circulation if your pool doesn't have floor drains and has few returns and this allows the chlorine level to get too low near the bottom of the pool. After brushing, you can try pointing one or more returns diagonally downward to try and create a swirling action to improve bottom circulation. The downside is that this will reduce surface circulation for getting material to the skimmer.
    THETOOLMAN's Avatar
    18
    Re: something new
    Thanks, I am going out for a good brushing now . Strange, everything seems the same as usual? Except for the slippy stuff & dust. I will get back with a report later
    Dan
    THETOOLMAN's Avatar
    18
    Re: something new
    Thanks, It seems to have gotten the slip out of the bottom with a good scrubbing . Now do y'all think I should give it a REALLY strong dose of clorox To teach it a lesson?
    Dan
    Re: something new
    Sure, raise the FC level a little higher than usual.
    Dec 2010
    San Diego, CA
    1,137
    Re: something new
    Have you performed an overnight free CL loss test?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    THETOOLMAN's Avatar
    18
    Re: something new
    OK, I won't make a bad thing worse As you see I have been a member for 2 years & am still a "NEW USER". So you gotta cut me some slack. I am still excited. I would rather be a SWIMMER than a new user
    Re: something new
    I like the idea of our user titles being swimming related that would be neat!
    Also, Tool Man... nice avatar!
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
