Results 1 to 16 of 16
Thread: Help - Pump won't prime on Pool Side
    Hello Fellow Poolers....
    My main filter pump, a Hayward Super II will not prime. I have checked all of the usual issues....water level, clogged strainers, etc. and still can't get the pump to pull water.
    My Jandy control system has automated valves that when put into SPA MODE the pump pulls water and primes. I have tried to start on the SPA side and switch to the POOL side and when I do I lose prime.
    I have changed the intake valves from SKIMMERS and MAIN DRAIN and still with no success.
    In the interim I have tried:
    - Placed a garden hose in the intake portion of the pump to try and blow out any blockage.
    - Used a wet/dry vac to try and suck any blockage out from one of the skimmers.
    - Used a pressure washer to try and clear out any blockage.
    Any suggestions from the group would be welcome.
    Squid
    PebbleTec pool with beach entry and rock waterfall/slide, Jandy Aqualink Wireless OneTouch, Hayward DE Filter, Goldline SWG, Polaris Black Max 380 with booster, Hayward Heater, 2 Blowers for HotTub
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Help - Pump won't prime on Pool Side
    Clarification, please: when you have things set to suck from the pool, and you stuff a garden hose into the strainer inlet, does water come out the skimmer, or into the spa, by chance?
    I'm wondering if the diverter valve is hanging up halfway between spa and pool, like from a stripped gear or something.
    it seems to fill up the pipes a bit then fills up the skimmer basket....but drains very quickly....does that make sense?
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by KidSquid
    If what I'm visualizing is accurate, I'd say you have a massive air leak in the skimmer line somewhere. This may take a lot more back-and-forth to isolate.
    30,403
    Richard's on the right course. Failure for a pump to prime is almost always a suction side air leak. So somewhere between the skimmer and the pump impeller, air is getting in to the system.
    Most common place is the 0-ring on the lid to the pump strainer basket but there are others as well.
    Has it primed easily in the past?
    Thanks for all of the input.....
    The pump DOES prime when the valves are set to SPA MODE.
    I've had trouble in the past with the pump priming.....but it typically has been water level.
    What should my next steps be?
    Squid
    I just noticed a little bit of water leakage around the PVC pipe that connects on the top....how much of a leak do you need before the pump won't prime?
    Squid
    Do you mean on the output pipe on the top of the pump? If you are seeing a water leak on the output side of the pump, that won't affect priming.
    If you can get the pump to prime in spa mode, try doing that, and while the pump is running very very slowly open the suction side valve to allow a little pool water into the system along with the spa water. The pump may well lose prime at that point, but if you are lucky you might get it that way. If you can't get it to prime that way, then there is an air leak somewhere between the skimmer and the valve on the suction side that selects between pool and spa.
    Looks like I have a underground suction side leak...ARGH!!!!!
    Anyone have a leak detection company in Houston they reccomend?
    Squid
    Well I had the leak detection folks out here today....and guess what they found......NOTHING....ABSOLUTELY NOTHING!
    I feel fortunate that my underground pipes are in good shape, but frustrated that i had to spend the money and still have a pool that will not circulate.
    The guy from the leak detection company did say he saw some small leakage around my Jandy three way valves....so I guess I will go get some o-rings in the morning and see if that helps.
    Hopefully I'll get this fixed before the pool turns green.
    Squid
    Dec 2010
    San Diego, CA
    1,137
    Have you checked to see if your impeller is clogged? I had trouble priming when mine was clogged. Also given that you said the pool won't prime from skimmer or main drain then a shared component like a suction valve to balance skimmer vs MD could definitely be a culprit.
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Re: Help - Pump won't prime on Pool Side - SOLVED
    Well what do you know......
    It looks like the o-rings on my Jandy 3 way valves were failing.....so after replacing 6 .89 o-rings I have a pump that primes and actually sounds better running that it ever has. Go Figure!
    I hate the fact that I had to pay for an underground test, but I guess I now have the knowledge that the pipes are good.
    Well...the pump is pumping....the cleaner is cleanin', the SWG is making chlorine....and I'm going in for a dip!
    Hope the process I went through helps answers others who may get in the same spot.
    Splashin' Away -
    Squid
    Dec 2010
    San Diego, CA
    1,137
    Sweet!
    30,403
    A suction side air leak (which is what you had) is easily one of the most common pool issues that has been posted on this forum over the years. It manifests itself in a failure of the pump to prime.
    What others should take away from this is that I don't think I can remember more than 3-4 instances when it was an underground pipe leak....if even that many. The air gets into the system at one of the connections, Pump strainer basket lid, etc. Any place there is a "joint" of two surfaces. ALMOST never a crack in the pipes.
    I have the same pump and am having trouble with it priming as well. Replaced the o ring on the pump strainer basket and that has not corrected it. Im not sure what else to check. Any suggestions?
    Cleveland, Ohio
    IG 36,000 gallons. Vinyl Liner, Hayward ProGrid 3620 DE Filter, Hayward Super Pump, Hayward Gas Heater
    22,543
    Check the drain plug(s) for a leak. HAve you ran water over it while it was running to see if that would help?
