Results 1 to 12 of 12
Thread: Peroxide
    Peroxide
    Just wanted to post for those that are not
    Aware of peroxide bring down the clorine levels.
    I saw in another post someone mentioning that peroxide will bring down fc
    So I gave it a wirl since my clorine was off the charts from the auto chlorinator.
    For my pool a 32oz bottle of 3% peroxide will bring down the fc about 1 full point (ppm)
    So I went to cvs and purchased 6 16oz bottles and dumped 5 in, within about 2'hours my fc is down to 3
    It was off the chart so needed to bring it down quick cause company was coming to swim
    Just wanted to post that it seems to work well and don't
    See any negative side affects
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Peroxide
    With typical CYA levels, your FC will still drop by 50% on a sunny day. There really isn't any reason to use peroxide or any other chlorine neutralizer, since its safe to swim in "shock" level FC.
    If your FC is 3, is that your "min" or above according to your CYA level? Refer to the CYA Chart.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Peroxide
    Welcome to TFP!!
    I also read about the effect of peroxide on cl.
    The state of Maine requires it's use monthly on public pools, but doesn't say why
    Thanks for pointing out the cl neutralizing effect of hydrogen peroxide
    Luv& Luk
    -Ted
    Sep 2009
    Greentown, IN
    914
    Re: Peroxide
    I saw that note to and am thankful someone mentioned it. I know it's "safe" to swim in anything under shock level, but prefer not to subject my child, or others for that matter, to levels very high. In the event that I misjudged my SWG timing it is nice information to have on hand.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Dec 2010
    San Diego, CA
    1,137
    Re: Peroxide
    How many gallons is your pool?
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Peroxide
    Roughly speaking, the rule is that the volume of 3% hydrogen peroxide neutralizes the same volume of 6% bleach. So you can use The Pool Calculator to calculate the volume of bleach for a given FC "Target-Goal" difference and that same volume is the amount of 3% hydrogen peroxide needed to neutralize that FC amount.
    Peroxide
    Our pool is about 19000 gallons
    18x33
    I think that other post said
    16oz per 7500 gallons or something like that
    I cleaned out cvs and the lady was looking at me funny when I went up to the register with all the peroxide they had in stock, got the last 32oz and 6 16oz bottles.
    I fear between the pool and my saltwater fish tanks if the cops ever come to my house they are going to think I'm running a meth lab or something? Lol!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Peroxide
    Quote Originally Posted by Highlandreef
    That sounds right since 16 ounces of 6% bleach in 7500 gallons is 1 ppm FC.
    Note that you can get 27% hydrogen peroxide in Baquacil Oxidizer where 1 gallon is $17. Compare that with a case of 12 bottles of 3% that are 16 ounces each where the case is $15 so that's 1.5 gallons. So the Baquacil Oxidizer is FAR less expensive for the amount of hydrogen peroxide you get. The Baquacil Oxidizer is equivalent in price to $1.89 per gallon of 3% hydrogen peroxide.
    Re: Peroxide
    While I think that it is good to know that you can reduce the FC levels if necessary, I think that it is important not to use it too often. Careful management of the FC levels will give the best overall performance.
    Support the site
    Mar 2007
    4,160
    Re: Peroxide
    I think they expect me to shock weekly, regardless as to the c.c. level (know nothings ) and then neutralize the extra chlorine to get back down under 4 ppm.
    Luv& Luk
    -Ted
    Jun 2011
    Central NJ
    19
    Re: Peroxide
    I think I am adding and not hijacking ... I thought the easiest way to explain is with a back story. Hopefully this helps someone else?
    Checking the math... Pool Calculator says I would need 4 gallons 1 quart 6% bleach to go from the high side of my target FC (8ppm with 45 CYA) to shock level (16ppm).
    To do the opposite and go from 16 down to 8 ppm after holding a high FC level (26+) to rid my pool of mustard algae and a planned bbq tomorrow.
    1) I would need 4 gallons 1 quart of 3% peroxide to lower from my current FC 16 to get back down to an FC of 8.
    2) Here is the main part... If I use the baquacil oxidizer, 4.25 gallons of peroxide divided by 9 (because the oxidizer is 9 times more concentrated than hydrogen peroxide) means I would need a little less than 1/2 a gallon of the oxidizer? 4.25/9= 0.47 gallons
    20' x 40' / 33,000 gallon / IG / Vinyl
    200lb sand filter / 1hp pump
    4hrs full sun with about 45 min part sun before and after
    Re: Peroxide
    LelandJF, your math look right. Calculating it a different way, I get 68 oz, so you are certainly in the right ballpark.
