Thread: Converting smooth return lines to threaded
    When my PB built my pool, they put in 1.5" and 2" return lines and a cleaner line - all just straight PVC piping. When they plastered, they simply cut off the extended PVC pipe at the edge of the plaster. While they left both return lines as is (smooth PVC pipe), on the cleaner line they inserted a white "cap" on the edge that provided a threaded end which enabled me to screw in my cleaner, fountain, etc. But I'd like to do the same to my return lines - so I can use a PoolSkim on the return (or fountain, etc.). Does anyone know if I can retrofit my PVC returns with one of these threaded caps, and where I can get them?
    20'6" X 38'6" (609 sqft)
    22,500 gal gunite/plaster IGP
    DE filter, Jandy 2HP pump, Nature2 Sanitizer (removed cartridge!)
    Raypak 39.9K BTU gas heater
    2 ColorLogic lights, Maytronics Dolphin pool cleaner
    22,553
    Re: Converting smooth return lines to threaded
    You can, but it might be some work. You can cut the pipe off inside the wall and use a threaded slip insert. To insert into the pipe ID.
