Thread: Algae in 18' x 48" intex pool
    I am a new pool owner and I'm having trouble with algae. I shocked the pool yesterday and the tests say the chlorine level is over what it should be, which I read was a good thing for killing algae. Yesterday the sides of the pool were slimy and now they fill clean like they should. I feel like I'm making some progress, but the pool is still green. Does anyone know how long it will take for pool to clear. And should I leave the filter on constantly until it clears? Thanks for any answers, I'm clueless but learning and this website really helps.
    Re: Algae in 18' x 48" intex pool
    Keep up with the shock level until it clears. Even if it is cheesy, the Intex vacuum can help get some of the solids out. I run the filter full time anyways since they flow so little; in your case I would check/change the filter element daily.
    Scrub and rinse the filter, then douse it with bleach. Dont want a reused filter to deliver the very stuff you're trying to get rid of!
    Didi you get all your chemistry right at the Pool Calculator?
    Thanks for the reply post. No my chemistry came from test strips, which I am coming to find out are useless. I bought a better test at home depot, and I'm going to retest in a minute. Thanks again. It really helps.
    Mar 2007
    San Rafael, CA USA
    12,082
    Even the test kit you bought at Home Depot isn't going to be good enough. You need a FAS-DPD chlorine test kit such as the TFTestkits TF-100 or the Taylor K-2006. If you describe the test kit you got from Home Depot, then perhaps you only need to supplement it with some single test components.
