Thread: New deck and water chemistry??
    Butterfly's Avatar
    South Carolina
    10,045
    We are having our deck refloored today and thought that all the sawing would be done far away from the pool. However, they will be sawing the outside boards (those that stick out over the deck floor) all at one time to get them even. That will put them sawing about eight feet from the pool and also about eight feet above the pool. If this treated lumber dust/'stuff' gets into the pool, which it probably will, what should we do?
    The pump is on and we have a sock in the skimmer.
    All comments appreciated!
    Joyce
    You're done SLAMing when:
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I'd remove the sock to avoid clogging it and losing skimmer suction. Stand by with the bug skimmer and pole to help things along.
    Butterfly's Avatar
    South Carolina
    10,045
    Thanks for the fast response, JT. We are more concerned with the chemical (arsnic?) that the wood was treated with mixing with our pool water. What do you think? All comments welcome!
    Thanks, Joyce
    SW Indiana
    9,199
    Treated lumber no longer contains arsenic. Primarily treated wood is soaked in copper compounds. My goal would be to get it out of the pool before it sinks and backwash or clean the cartridge as soon as the filter has it gathered up.
    Butterfly's Avatar
    South Carolina
    10,045
    Perfect timing, JT, the crew just got back from lunch! Thanks so much for the info. We'll try to keep it cleaned out as we go. Then will vac and backwash. Copper?....... guess if the pool turns green we'll know what it is!
    Again, THANK YOU!
    Joyce
