Thread: Could this be where my leak is?
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    Just as an after thought to a previous forum topic ..... The last time i put the polaris in the pool before it broke I had a hard time unscrewing the eye from the return line where it screws into the pool runs through the wall. I finally got it to turn but not before the whole attachment was turning inside and out. What are the chances that that is where my leak is ?? I did a leak check with dye today and no dye got sucked in or around the return inlet, mind you the water level has now drained to that level where the return is ....
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    You will know soon, either the water will keep going down or it won't.
