Thread: Adding Bleach according to pool calculator
    Jun 2011
    Evansville, IN
    18
    FC 4; CYA 80; pH 7.2; TA 120
    I want to increase the FC due to a group coming to swim. I plugged in my numbers in the pool calculator (first time to use it).
    I listed the above numbers, the size of my pool in gallons and the goal of an FC of 9. I hit the calculate button and the result was to add .2 oz of 6% bleach.
    Could this possibly be correct? Sure didn't sound plausible.... So I figure I am doing something wrong again!
    Thanks!
    Bewildered in Indiana
    Susan
    SWG; IG; 17,200G; Sand; Hayward S244T, 1.5 HP
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Adding Bleach according to pool calculator
    I suspect a typo on your part.
    Also note that sometimes you have to go down a box or two before it updates.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    I get 178oz, but if I put in 17.200 gallons it tells me 0.2oz.
    Oct 2010
    Georgia
    317
    Take out the "," or "." and input 17200 in the size field.
    poolschoolgrad
    20x40 free-form IG vinyl, 1hp Hayward superpump, Hayward pro grid DE filter, Raypak heatpump, Goldline Aquarite SWCG, Polaris 280 with booster, and tested using a Taylor K2006.
    Jul 2009
    Olney, MD
    218
    Encourage your guests to splash a lot and do lots of cannonballs. This will help aerate and raise your Ph without raising your TA!
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Jun 2011
    Evansville, IN
    18
    Thank you all once again! Lifesavers!!!
    Susan
    Susan
