Thread: Tidewater by Jacuzzi Info needed!
    I need help as Google is not being a trusted friend on this.
    I cannot find any information on the sand filter installed on the pool.
    It is a Tidewater by Jacuzzi so old the labels on it are blank. I know next to
    nothing about this filter except that it measures 18" side to side.
    I bought this house 2 years ago with the pool installed. Being as it is a 18'
    round above ground pool this filter is probably a bit over sized but I don't
    want to replace it if all it needs is a part or two.
    Last year there was a little sand in the pool not much but this year there are loads
    after opening it and the initial backwash. I spent 20 years in apartment maintenance
    including pool care so I have a pretty good idea what is going on when it comes to pool
    care and maintenance but I am not an expert. I realize that there is probably a split
    lateral or two in the filter and it may be a good idea to change the sand out though
    it is doing a good job.
    My questions are, does anyone have any info on this unit? There is NO info online I can see.
    Where would I get spare parts like replacement laterals? Are things interchangeable?
    Are the laterals on this unit glued in or threaded? I realize I will find that out when I
    tear it down but I would like to spend a day not a week when I get to shutting the pool
    down for repairs.
    If I need a new lateral assembly what am I looking for in a replacement? Suggestions?
    Thanks for any help in advance.
    Our is pool is a 33,000 gallon ig concrete pool with a cartridge filter.
    22,553
    Re: Tidewater by Jacuzzi Info needed!
    What you have is most likely the 190L filter. There is a lot of info available on that model. Take a look at some of it and see if it matches what you have.
    It's most likely only a lateral or two that's cracked but you won't know that until you get it torn down.
    Thanks for the reply.
    I am seeing parts for this model listed using Google but not much in the way of information.
    Do you know where I might get more information on it or ideally a manual of some sort?
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    I tried finding lateral replacements (screw-on type) to no avail. The top and bottom of the round centerpiece to which they are secured came apart at the weld. I ended up PVC glueing the whole thing together so it's in there permanently now. Not much in the way I was able to find on documentation except for a pdf on a Jacuzzi "Laser" which seemed to be identical. I can make that available if you like.
    My next repair step is to replace the spider gasket so I'm still refurbishing mine.
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Thanks kincer, I sent a PM to you about the pdf. I would like that.
    I found a replacement lateral assembly on Amazon for $49.95 specifically
    for the Jacuzzi Laser 190L which seems a very good price. I will most likely
    draw down and empty the filter tomorrow to inspect the laterals and see what
    is necessary.
    Th spider gasket for the valve seems pretty stock and I replaced that last year as well as the
    "O" ring gasket. It calls for a square one (OEM) but a stock round one from the local pool
    supply store of the same size worked just fine but the square one is also available from Amazon.
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Local pool store had a diverter (apparently gasket is hard-fused to it) for $40. The circle gasket was $13.
    In the documentation at the bottom of page 14 there is a DV6/ 7 Repair kit that I've been able to locate online, a few sources, for much less even after shipping. Double-checking stock before ordering though has proven most of these are phantom listings. The only store to claim they had them in stock was poolcenter.com which, according to an email I just received, just shipped (took forever but the price is right).
