Thread: NO pump pressure
    NO pump pressure
    Pumpin lots of water but pump pressure registers ZERO. Running a Barracuda, and doesn't seem to be picking up right. It's movin, but not as fast as it should. Unhook it from the skimmer and no real difference in the water flow. Open both valves and I get more water flow but still registers zero on the pump gauge. Any thoughts?
    JJ
    15K gal IG plaster pool
    DE filter
    1 horse pump..don't know flow rate
    Chlorine Feeder
    Pool Newbie (only 3 1/2 years)
    Re: NO pump pressure
    The gauge is probably broken. They break frequently, and are inexpensive to replace.
    Thanks! Could be but my Barracuda isn't runnin like it should be. Had to clean out that line from the skimmer to the pump here about a month ago and maybe that's getting stopped up again. Probably is the gauge but still have something amiss.
    About to put some marinated venison strap wrapped in bacon and stuffed with jalapeno on the grill along with some squash on the grills. I'm starvin!
    Thanks again!
    JJ
    DE filter
    Chlorine Feeder
    Mar 2007
    Coastalish 'down easter'
    4,160
    Check your pump basket and impeller for obstructions
    Luv& Luk
    -Ted
    Thanks! Will do!!! I appreciate it so much!!!
    JJ
    DE filter
    Chlorine Feeder
