Thread: Reducing CYA by draining my vinyl inground pool?
    Jun 2011
    Columbus, Ohio
    17
    So I am reading the only way to reduce my CYA levels (150) is to remove water. So today I started pumping out the water from the pool and came inside to read a bit. I was going to remove all the water down to the shallow end then refill but got frightened when I read that removing too much water can destroy the liner do to hydrostatic pressure. I removed the water to about a foot under the skimmer and am now refilling.
    If I can't get the CYA out of the water by draining it, how would one do such a thing?
    14x28 inground rectangle vinyl lined pool 3ft on shallow 6ft on deep end.
    Taylor k2006 test kit.
    30,421
    Re: Reducing CYA by draining my vinyl inground pool?
    Do multiple drain/refills. Drain a foot, add a foot, drain a foot, add a foot.
    Jun 2011
    Columbus, Ohio
    17
    Thanks, that's what I am going to do, better safe than sorry I suppose.
    On the upside today I learned that a kink in your backwash hose creates one heck of a water balloon. My neighbor said it sounded like a gunshot..
    Butterfly's Avatar
    South Carolina
    10,045
    holy cow!
    The only other option to reduce the CYA is RO, if it is in your area. Don't see your location in your profile.
    You're done SLAMing when:
    Jun 2011
    Columbus, Ohio
    17
    Quote Originally Posted by Butterfly
    holy cow!
    Not sure what RO is but I live in Columbus, Ohio. This is our first house/first pool so this is a learning experience for me.
    Butterfly's Avatar
    South Carolina
    10,045
    Well, okay Ohio. I don't think the RO (Reverse Osmosis) treatment is available there.
    So, your only option seems to be the "water dance", aka, drain some, refill some, test; drain some, refill some, test.........
    welcome to the forum
