Thread: what kind of test strips should I get?
    May 2011
    Missouri
    5
    I have to give my boss a list of supplies I need for the community pool. The test strips we have only test the ph, fc, alk, and cya
    they are really inaccurate and have a different outcome when i use multiple ones at the same time.
    1) 45000 gallon
    2) sand filter
    3) Inground
    4) If it's IG, tell us if it's vinyl, plaster/pebble, or fiberglass
    5) 5hp
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: what kind of test strips should I get?
    If you want to test the pool accurately then you will not be able to do that with strips. What you need is a drop based kit, such as the TF 100 or the Taylor k2006. Check your local regulations to see what the required chemical levels for public pools are for your area.
    Love TFP? Become a
    TFP Supporter!
    May 2011
    Missouri
    5
    its a private pool in a private community nom sayin
    1) 45000 gallon
    2) sand filter
    3) Inground
    5) 5hp
    I have no idea what the rules are in Missouri, but in all of the states I am familiar with, that counts as a public pool, even though it is not strictly "public".
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    None. Get a drop test kit.
    Whoever operates that pool is liable. If someone gets pinkeye, a urinary tract infection, anything at all, really, and they feel like suing, I'm sure a lawyer would have no problem convincing a jury that there was negligence involved.
    The Center for Disease Control has recommendations that should be the minimum a community pool should follow; most states or counties have tougher ones. Just as a for-instance: someone has diarrhea in the pool. They say
    Raise the free chlorine concentration to 20 ppm and maintain pH 7.5 or less and a temperature at 77°F (25°C) or higher. The free chlorine and pH should remain at these levels for at least 12.75 hours to achieve the CT inactivation value of 15,300. Crypto CT inactivation values are based on killing 99.9% of Crypto. This level of Crypto inactivation cannot be reached in the presence of 50 ppm chlorine stabilizer, even after 24 hours at 40 ppm free chlorine, pH 6.5, and a temperature of 77°F (25°C). Extrapolation of these data suggest it would take approximately 30 hours to kill 99.9% of Crypto in the presence of 50 ppm or less cyanuric acid, 40 ppm free chlorine, pH 6.5, and a temperature of 77°F (25°C) or higher.
    emphasis added.
    How are you going to read 20 ppm accurately on a test strip? And just how accurate is that CYA reading?
