Thread: Muriatic acid and swimming
    Guest
    I just added some muriatic acid to lower my PH because it was at 7.8 and my TA at 160. The pump is running of course but how long do i need to wait before I can swim? It's HOT lol.
    Jul 2009
    Olney, MD
    218
    Re: Muriatic acid and swimming
    What was your method for adding it?
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Guest
    I poured it into the pool over the return with the pump running.
    Jul 2009
    Olney, MD
    218
    You have a very large pump for your pool size... anyway, I would check the ph again in 30 minutes and if it is acceptable, go for it!
    If you really want to be cautious, you could even brush for 10 minutes, that would be sure to get it all good and mixed up prior to testing.
    Guest
    7.2, TA only went down to 140 so still a bit high but that can be fixed with some bubbles and more acid later, time for swimming! Thanks!
