Thread: Brushing the pool
    Feb 2011
    Central Texas
    187
    Brushing the pool
    How often do you all brush the sides of your pool. I brush the bottom weekly, but usually skip the sides. Seems like there is just nothing there to brush.
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
    Feb 2008
    Denton, TX
    5,061
    Re: Brushing the pool
    Once every couple of days.
    Butterfly's Avatar
    South Carolina
    10,045
    I have read many times that none of us brushes the pool often enough!
    Weekly is what I always aim for. And, brush the entire pool.
    You're done SLAMing when:
    Mar 2007
    San Rafael, CA USA
    12,082
    I try and brush the entire pool weekly during the swim season. It's true that there often isn't anything visible to brush away, but the circulation right at the plaster surface is always the worst so brushing helps ensure that chlorine gets introduced right to the plaster and brushes away any microorganisms that might have started to grow (be it biofilms or algae), killing them by exposure to chlorine in the bulk pool water as a result. It's just a preventative measure. In practice, the only place in the pool I've felt any sliminess or slipperiness at all is at the top of a ramp with poor circulation because it has only about a half inch of water above it (see my pool) and even then it's barely noticeable unless I don't brush for several weeks.
