Thread: How does the cooler weather effect the pool chem?
    Aug 2007
    Austin, TX
    343
    1) How does the cooler to cold weather effect Chlorine, pH, alkalinity, stabalizer and such?
    2) Since the bather load will be almost nil, what gets into the pool water that needs to be killed?
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Mar 2007
    Coastalish 'down easter'
    4,160
    The one that's really effected is the chlorine, at colder temps you have less use, as you pointed out, and algae and other nasties have a harder time 'breeding'. So you will find that your chlorine stays around a little longer without having to add more The other chems which play into the indecies have a temp factor but it's usually not anything to worry about. About the only thing which will cause a major chlorine demand are the leaves, but if you don't let them pile up on the bottom your chlorine demand should continue to go down with the temps
    Luv& Luk
    -Ted
