Results 1 to 11 of 11
Thread: 100-110 TA with about 6.9-7.0 PH
    New Engalnd
    114
    should i be concerned about that total alkilinity reading?
    Matt
    Hayward Pump 3/4 HP - brand new
    sta rite sand filter - not sure of size, i will get back to this
    20 by 40 inground pool, vinyl liner, 8ft deep end
    2 skimmers and a main drain.
    1 jet in the deep end, 1 jet in the shallow end.
    Live in New England = about 3 months of pool usage.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: 100-110 TA with about 6.9-7.0 PH
    Try aerating to lower it down. It will come down on its own.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    TA around 110 when you don't have a SWG or fountain or waterfall or other water feature is not a problem. If you find that the PH is going up on it's own annoyingly quickly, then worry about the TA, but otherwise you can just leave it alone.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    Try to keep 7.2 as your minimum number for PH.
    New Engalnd
    114
    how do you aerate? is there a thread on the instructions??
    Matt
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by maxepr1
    Aerating does not move TA, so is used to raise pH while leaving TA alone.
    You're done SLAMing when:
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Mattyssox
    Aerating only raises pH. If you are trying to lower your alkalinity, see Pool School complete instructions for "How to Lower your Alkalinity".
    If you do not have any of the features Jason mentioned, you are fine with your TA where it is.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by woodyp
    ^^ ditto
    New Engalnd
    114
    awesome..added 3 boxes of borax (as the pool calculator described) and now up around 8.0 on the PH. from about 6.8-6.9 to 8.0. the pool calculator said it would raise it to 7.2.
    GRRRRRRRRRRRRRRRr
    Matt
    Butterfly's Avatar
    South Carolina
    10,045
    First, always only add about 2/3 of recommended amounts. Circulate, retest, adjust. Add more if needed.
    Testing can be off. Re-check your input info in Pool Calculator.
    Post the info you used and we'll try to check it for you in Pool Calculator.
    I don't know what your FC is right now, but if it is over 10, wait til it drops below 10 to retest pH.
    New Engalnd
    114
    That could be part of the issue. I'm keeping the FC really high (in the late stages of shocking from first opening up)
    Matt
