Thread: swapping parts
    swapping parts
    Have an older intex swg w/o copper it won't turn on. I think it has something to do with the electronics. I went ahead and got a new 8110 with copper. What I would like to know if I could hook up the old plates to the new swg? I believe they will still produce chlorine. So, if I use the old plates on the new swg could I produce 24 grams per hour instead of the 12 the new ones produce? Just thinking outside the box or plates in this case.
    16' X 48" Ultra Metal Frame 1500 gallon pump
    Re: swapping parts
    I don't really know, but it seems unlikely that the new power supply would produce enough power for the larger cell.
    22,542
    Re: swapping parts
    As Jason said, it's all about the power supply. If they're the same it'd work fine but if the newer model has a smaller one then it'd burn out shortly.
