SWCG output question
Sep 23, 2010
54
SC Lowcountry
I measured the chlorine level on my return water and a question came to mind. Is the actual chlorine production a constant (5 ppm in my case) for the % of normal pump run time? Is the output greater during Super Chlorination, or just 5 ppm for the entire run time? I'm assuming water temp and salt level would have some effect.
Thanks
What ever % you have it set at it basically runs that amount of the time. 50% its going to run the equivalant of 30 mins. for every hour of run time. Super chlorinate full 100% all the time. And it's not 5ppm if thats what you've been at. It's more like whatever it can produce in the amount of time it's running for. For boosting FC after high loads.
