Thread: SWCG output question
    Sep 2010
    SC Lowcountry
    54
    I measured the chlorine level on my return water and a question came to mind. Is the actual chlorine production a constant (5 ppm in my case) for the % of normal pump run time? Is the output greater during Super Chlorination, or just 5 ppm for the entire run time? I'm assuming water temp and salt level would have some effect.
    Thanks
    Viking Laguna 14K IG , Smart Pure SWCG, SwimClear C5520 Cartridge Filter, TriStar 1.5HP, SmartControl PLP4 controller.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: SWCG output question
    What ever % you have it set at it basically runs that amount of the time. 50% its going to run the equivalant of 30 mins. for every hour of run time. Super chlorinate full 100% all the time. And it's not 5ppm if thats what you've been at. It's more like whatever it can produce in the amount of time it's running for. For boosting FC after high loads.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
