Results 1 to 9 of 9
Thread: Pool is finally clear!!!
    Apr 2010
    Syracuse, NY
    103
    Just wanted to share the good news, and to encourage anyone who is having a hard time clearing their water. After about 3 weeks of continuous shocking, running the pump 24/7, vacuuming, and brushing, the pool is finally clear. All it basically took was chlorine, elbow grease and patience. I didn't think this day would come. The progress was slow and steady, but there was daily progress as long as I kept the petal to the metal. WHAT A RELIEF! Thanks to TFP big time!!
    20,000 gal., Jacuzzi 250L Laser Sand Filter, inground w/vinyl liner, 1hp pump motor, TF-100 Test Kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,008
    Re: Pool is finally clear!!!
    Got any before and after pictures?
    You will stick around and help convince others that we have a better solution than the pool store, won't you?
    Sep 2009
    Greentown, IN
    914
    Awesome! Everyone likes to hear the success stories!
    Enjoy your pool
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    took approx. one week with my swamp... just chlorine,,test kit,,brushing at every chance,,and patience.... i only run low on patience at times.
    pool store said i was the only one that used just 12.5% chlorine....they are good enough to keep it in stock for me so i buy parts i may need from them,but my "opening the pool supply list" was sorta short,, chlorine and a new leaf net! TFP is the only way to go.......
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Apr 2010
    Syracuse, NY
    103
    Here's a photo after about 4 days of trying to clear. Seeing the bottom step was a victory! Just picture crystal clear water for the "after" picture. It took about a week to get rid of the last tinge of green cloudiness. I don't even want to say what I think flowed into the pool during the heavy spring rains. Last week we had a 150' french drain installed to "try" and avoid future problems.
    Butterfly's Avatar
    South Carolina
    10,045
    ew, edweather, that looks nasty
    Now, when can we see a pic of the rest of the story?
    Congratulations on your victory
    You're done SLAMing when:
    May 2009
    NC
    136
    Congrats! Would love to see an updated pic.
    I'm still looking for the light at the end of the tunnel....on day 11 now and haven't seen much change since last week. Can be really discouraging, ya know. Still have yet to see the bottom. Trying to have patience.......
    24' Round 52" High AG, Waterway 125 SF Pro Clean 2HP, 2 SPD Cartridge Filter
    Pool Rover Jr. /TF-100 Test Kit/ BBB - Ex Baqua User
    Apr 2010
    Syracuse, NY
    103
    Here's the "after" picture. Don't mind the liner creases or the fact that the return is jossiling the surface a bit. The water is crystal!
    dattia's Avatar
    Jun 2008
    West Chester, PA
    511
    Congrats edweather!!! Hang in there Stephanie, mine finally turned clear too... it will happen for you as well!
    27' round AG
    Hayward Matrix 1 1/2 HP Pump
    Hayward S210T Sand Filter
