Thread: Salt system/cell failure
    Pro-matic ESC 24 salt chlorinator. Two red lights on the control box. My pool engineer says that the salt system is defective because I turned off the system during the winter season but did not bypass the cell so pool water continued top flow through it. Is this correct ? He also said that I should not be supplementing the chlorine in the pool when it is low due to sudden bather load etc with sodium hypochlorite. "A salt system does not need additional chlorine".
    Ralph
    TF50 test kit
    9800 gal.
    15x25 oval; AG
    Hayward sand filter with zeobrite; Hayward pump 1hp pro-max flow, or something like that, LOL!
    Southwest MO; hot/humid summers, full sun 8am-1pm, then shading begins.
    Apr 2009
    Burlington, ON, Canada
    344
    Re: Salt system/cell failure
    Quote Originally Posted by keenwilk
    Ralph
    If he says that (about the extra chlorine), I would use the term 'pool engineer' very loosely...
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    There is nothing wrong with leaving the cell in place when the control unit is off. Likewise, as rcy already pointed out, there are lots of reasons to supplement the chlorine produced by the SWG manually, though if you are doing so constantly that suggests something is wrong.
    Thanks rcy but would you please qualify your comment. I'm after information.
    Ralph
    Ralph[/quote]
    If he says that (about the extra chlorine), I would use the term 'pool engineer' very loosely...[/quote]
    TF50 test kit
    9800 gal.
    15x25 oval; AG
    No. I'm not supplementing constantly. I just want to make an instant adjustment without playing catch up with the control dial. Could you list the reasons for me ?
    TF50 test kit
    9800 gal.
    15x25 oval; AG
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    The bottom line is that there is something wrong with your SWCG. I hope you are successful in either repairing or replacing it. How long have you had it and the pool? Giving us information on your pool and equipment is helpful.
    As for adding bleach when the demand rises--there's no problem with that.
    Do you have a very good test kit? Do you do your own testing?
    It seems your pool guy isn't very helpful or knowledgeable (as per his comment about the bleach and your writing here instead of him finding the problem with the SWCG); I hope you find the info you need. Do you have a manual for it, or can you find it online?
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
