Thread: Phosphate buildup on salt cell?
    Apr 2009
    Burlington, ON, Canada
    344
    Found this tidbit online. Is this possible? I know phosphates aren't a problem if the chlorine level is in the proper range based on the CYA level, but if they can affect the output of a chlorine generator, then keeping the chlorine at the right level becomes that much harder.
    "Q: Why are phosphates even more problematic for chlorine and bromine generators?
    A: Filming of the electrode media…
    Phosphates are known to bind to the cathode of chlorine and bromine generating electrode cells causing a reduction or elimination of bromine and chlorine production, rendering the pool or spa unsanitary. "
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Phosphate buildup on salt cell?
    I believe the problem with the salt generator is calcium build-up, do to the lack of a balanced pool.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    That really isn't an issue. There is a technical discussion of why in this topic.
