Results 1 to 8 of 8
Thread: Algae or Metal problem
    N. Liberty, IN
    8
    I have shocked the pool and kept the fc levels above 10 ppm for at least 2 days now. I"m using strips so i'm kind of guessing but its definitely been above 10 and held that over night. My pump is not building any pressure since last backwashed well 1 psi. i have test results from 5/28/11 that i got a my local pool store i'm just showing copper and iron content, they are:
    Copper- 0.3 ppm
    Iron- 0.3 ppm
    That was after i added a bottle of sequa-sol.
    My Numbers now are:
    FC- 10 ppm
    PH- 7.5
    Alk- 76
    CYA-61
    I don't have any updated copper or iron numbers. My question is do you think i have an algae problem or metal problem. Here's a link to some pictures i just took today at approx. 3 o'clock e.s.t.
    http://s875.photobucket.com/albums/ab317/mindshank/
    13,500 Gal., Swim Pro SW256T Sand Filter, 24' Dia. x 54" A.G., 1 1/2 HP Hayward Pump, Hayward CL-220 Inline Chlorinator, Tri-Chlor As Primary Sanitizer And Bleach To Shock
    Sep 2009
    Greentown, IN
    914
    Re: Algae or Metal problem
    You really need to get a good test kit and see what your FC levels really are. For a CYA level that high, you will need to be well above 10 FC to shock your pool. If you can only read up to 10, you really don't know what your reaching.
    Check out the http://www.poolcalculator.com/ and put your numbers in to see how high your FC needs to be to shock the pool. If your pool sticks showed above 10, it could have been anything above 10 so you can't truly say you held your chlorine overnight.
    Example... maybe your chlorine was at 17 and overnight it went down to 11, you have no way of knowing that you lost that much chlorine with the test strips you are using. Chances are, with your water looking like it does, you're not holding your chlorine overnight like you think.
    I honestly can't say if levels of iron and copper that low will produce murky water. Usually green or brown, but you could possibly be dealing with both problems. Hard to say w/o accurate numbers.
    How did your pool look before you started adding anything? Is this a new fill or just opened from last year?
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Nov 2010
    South Central Kentucky
    283
    For a CYA level of 61, your FC needs to be at ~24 ppm to be at shock level. I recommend the same for getting a good test kit so you can know exactly where your FC is and if you are keeping it where it should be for shocking and maintaining after the water is clear.
    The typically recommend way to add FC here, especially when your CYA is already near maintenance level, is liquid chlorine (bleach). The pool store pucks or bags of shock typically contain other additives besides bleach, which may leave you in worse shape when it comes to maintaining your numbers.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    That is at least mostly algae. There might also be a metals problem, though I kind of doubt it. Metals will never cause the water to be cloudy or murky. You need to shock the pool, see the article on how to shock your pool in Pool School.
    N. Liberty, IN
    8
    Yep it was algae, water is almost completely clear just a little cloudy. Hopefully it's crystal clear by this weekend. I've been swimming in it all day though. And I will be buying a t-100 test kit this weekend. Thanks for the help and the abundant wealth of knowledge offered at TFP.
    Butterfly's Avatar
    South Carolina
    10,045
    Well,
    Now when that water gets all sparkly, we'd like to see a pic!
    Welcome to the forum
    You're done SLAMing when:
    N. Liberty, IN
    8
    Here's a link to the pics I took this morning.
    gordyjamz's Avatar
    Aug 2007
    Illinois
    34
    Yeah, I had a copper problem last year, which a friend helped me out with. He works at a waste water treatment plant. Long story short, we raised PH to above 8 to precipitate everything, than used an industrial floc which he acquired for me (wink, wink) to settle it and vacuumed it out. Then, brought ph down and went from there. From my experience, if its copper, the water will still be almost crystal clear but have a green tint to it. Algae will cause green and cloudy. Glad to see you got it clear. Happy swimming!
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
