Results 1 to 14 of 14
Thread: Wire gauge for long speaker runs?
    Jan 2010
    Northern Virginia
    282
    I'm about to install some outdoor speakers on the far side of my pool (from the house). It's about a 250 foot run from the amp to the speakers. Does anyone have any advice for the proper speaker gauge?
    The local Paradigm dealer was recommending 12 or even 9 gauge, which he sells for $4/foot!!! I checked out what an electronics big box store had and the largest they had was 16 gauge. The guy in there told me that with the low resistance and efficencies of modern speakers, you didn't need to go larger than 16 gauge. He said he's been in the home theather design business for 30 years (to give credibility to his statement).
    So what does anyone think? Is 16 gauge big enough for a 250 foot cable run?
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: Wire gauge for long speaker runs?
    Just like filters, speaker gauge is better Bigger! If bigger yields a response from the nieghbors...then good job!
    Bigger is better...having 'inhereted' a less than optimal system from the former owner. Pay for quality...it will pay you back!
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Aug 2010
    Dallas, TX
    4,052
    Hey, here's an idea for you... I've done this on high-powered systems and it WORKS. (I was a sound engineer for a band for 7 years, and owned a roller rink for more than 20).
    Get stranded electrical wire from your Home Depot / Lowe's / etc. It's far cheaper. The bigger gauge the better but 14 would be minimum IMO. You could go up to 10 gauge if you wanted. MAKE SURE YOU GET STRANDED, NOT SOLID. If you are burying it, you can even get the stuff for outdoor use.
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Wow that's a very long run. I'd definitely get the heaviest gauge wire you're willing buy. Like RobbieH said, stranded will make life a lot easier. Also, don't sweat the expensive wire gimmicks, home depot/lowes etc... is going to be fine.
    Here is a link that a number of folks on home theater forums reference when it comes to speaker wire gauge/general info http://www.roger-russell.com/wire/wire.htm. Scroll down a little you'll see a chart that reads "Maximum Wire Lengths For TWO CONDUCTOR Copper Wire"
    I think 250 is beyond the recommend distance for 10 gauge but close. Frankly they don't generally recommend going over 50ft, but there's a big difference between a critical space like high end listening room/home theater and a backyard pool deck. You'll probably be fine with just going with the heaviest gauge wire you're willing to buy.
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Aug 2010
    Dallas, TX
    4,052
    If you go 10 gauge, just tell them at the hardware store you need X amount of feet of 10/2 electrical wire. It won't be cheap. I did a quick search online and 250' is $150 or so. BUT, that's a lot less than $4 a foot!!
    Aug 2009
    Lehigh Valley PA
    9
    Well, my dh ran wire for our pool and it was about 100 ft. He used low voltage landscape lighting wire and it was a lot cheaper. Not sure what the gauge is .We have Boston Acoustic speakers and it sounds great!
    27,000 gal freeform, 3ft.-7.5 ft., 675 sq.ft., 50 sq. ft. 18" raised spa w/ 2 hp blower, 60% Color quartz plaster, Hayward 450 sq. ft. cartridge filter, Hayward 2hp 2 speed pump, 400,000 BTU propane heater, SWG, Goldline PS 8, Hayward Phantom cleaner
    Jan 2010
    Northern Virginia
    282
    Wow! Thanks for the quick responses folks!!!
    Mar 2010
    Spring, TX
    1,082
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    May 2011
    Orange County, CA
    696
    I've also used low voltage cable and it seems to work fine. I think it was 14 ga, but for a long run like you are talking, 12ga would be better. This should be cheaper than what you were quoted. Just try to maintain polarity between the L/R pair.
    250 over any cable at speaker levels is always problematic. This is due to the low impedance of your speakers (probably 8 ohms). Relative to that 8 ohm load, your cable resistance starts to become more and more of a problem over increased length. An alternative is to run high impedance line pre-amp outs and use an old stereo receiver aux channel to drive your outdoor speakers. For this, you could easily get away with twisted pair (e.g. in Cat5). Better yet would be to use baluns that balance the signal to the extra receiver.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    You could also run a 70 volt line with transformers at the amp and speakers like used in PA systems with VERY long wire runs. This would allow you to use smaller gauge wire, but the cost of the transformers and smaller wire could add up to the same as just using larger wire.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    Feb 2011
    Central Texas
    187
    I think 14 ga wire would be fine. Look at http://monoprice.com. They have great prices and quality stuff. Built out my media center with their wire and wall plates, and then did it again for the pool just a couple of weeks ago. The have the CL2 rated 14 ga wire for way cheaper than you can get it anywhere else.
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
    Aug 2010
    Austin, TX
    200
    Run the same wire you are running for low voltage wiring. Should be more like 1$/foot.
    Insane to spend more.
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Mar 2011
    441
    Quote Originally Posted by shakenbake
    IMO $1 per foot is insane $.30-.50 is my happy place.
    I could argue speakers in a controlled environment COULD sound better with better cables, but outdoor speakers it's a complete and total waste to buy good cable.
    20X40 30,000 gallon gunite pool
    An hour NW of Philly
    76
    I'm putting in a pair of speakers soon myself, though mine will only be 90' away. I'm going by these recommendations:
    http://www.roger-russell.com/wire/wire.htm#wiretable (Edit: Puffin, I see you referenced that site too....I need to read more before posting.)
    There's lot's of technical stuff on that site too if you are into that.
    I have an 8 ohm impedance pair of speakers so I'm going to use the same 12 gage wire I used for my landscape lighting.
    27k Gal, IG Plaster Ansylbrite, Pentair FNSP60 DE Filter, Jandy Aquapure APURE1400 SWG, WhisperFlo WFE-28 pool pump, WhisperFlo WFE-26 Waterfall pump, Raypak P-R406A-EN-C Heater, Polaris 1-470-02 Air Blower, Jandy PDA 4.1a firmware
