Thread: TC AND FC----TEST STRIPS
    As of today i only have test strips to check my cl, i plan to order the test kit recommended. So should the fc be equal to the tc on the strip. these are the only 2 on the strip. the test shows my fc is greater than the tc. i know this is terrible info,but any help today would be a blessing. THANKS.
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
    Voodoo_Pool's Avatar
    May 2011
    On the border AR/TN
    82
    Re: TC AND FC----TEST STRIPS
    My suggestion is to get a quality test kit. Take control of your pool and the H2O contained within. You have the ability...aloha!
    IG Vinyl 27,000 gallon "L" shaped (new vinyl April 2018) with spillway spa; Hayward 4820 DE; Polaris 380 w/ booster; TF-100 Test Kit w/SpeedStir
    Aug 2010
    Dallas, TX
    4,052
    It isn't possible for FC to be greater than TC.
    FC+CC=TC
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    You can head to Walmart and get a 5way kit that at least uses a drop test for chlorine till the "good" one comes in.
    robbie,the test strip fc is dark purple and the tc is very light blue. according to the numbers above the color,the fc is high for dark purple and lower for tc. fc # is a 10,tc # is 3. this is an aqua chem 6 way test strips. am i in danger to swim in this water.
    Mar 2007
    San Rafael, CA USA
    12,082
    It is impossible for the FC to be higher than the TC. This is just one reason why using test steps is bogus. Without knowing an accurate Cyanuric Acid (CYA) level we can't tell you if it is safe to swim -- with no CYA it would not be safe, with a higher CYA it would probably be fine. Of course, that assumes we could trust the FC reading at all, which we really can't. See this post for a comparison of the resolution of test strips vs the two drop-based tests we recommend on this forum.
