Thread: How to tilt the return outlet on my Intex AGP?
    May 2011
    London, UK
    46
    Hi all,
    I've a 15' x 42" round Intex AGP and the return outlet in the pool tends to point upwards due to the weight of the flexible pipe full of water. As I'm fitting, hopefully tomorrow, an Espa Silen pump which is more powerful then the lame supplied Intex filter pump I feel that this tilt will cause the water to spray in the air. Is there a way I can hold the return outlet down at an angle?
    I'm sure that I'm not the only one with this issue and would like to see some peoples clever solutions.
    Thanks
    Darren
    CERLAND OCTAGONAL ABOVE GROUND POOL
    Re: How to tilt the return outlet on my Intex AGP?
    Mine does the same thing. I am thinking about modifying the screw on cap by removing the inner and outer gratings to increase flow, and doing a bit of surgery to graft an 90 degree plumbing fitting pointed at about 4 o'clock to get a circular flow pattern.
    docchop1's Avatar
    Apr 2011
    Southern Indiana
    61
    I can't find it now but another poster has a picture showing a small rope lifting and holding up the the hose and fitting outside the pool, forcing down the front inside the pool. In the picture the rope is going from a t-joint down and under the end of the hose fitting and then back up to the next t-joint forming a rope "v". My pump/filter came with one of these http://www.intexstore.com/ProductDet...ges&parts=list and it works ok too. The eyeball in the middle is adjustable and when used as an outlet only the eyeball holes are open.
    Intex 15x48, Intex Saltwater Chlorine Generator, Intex 14" Sand Filter, TF-100 unicorn eating spaghetti while riding a unicycle on a high wire during a storm edition test kit,
    http://tftestkits.net
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    I was thinking some kind of bungie cord would do the trick.
